주요 콘텐츠로 건너뛰기
Amazon Echo Dot 5th Generation Motherboard Replacement
필요한 것
  1. Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Motherboard Replacement: 2 단계, 이미지 1/1
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Motherboard Replacement: 3 단계, 이미지 1/3 Amazon Echo Dot 5th Generation Motherboard Replacement: 3 단계, 이미지 2/3 Amazon Echo Dot 5th Generation Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
결론
Grace Warila
회원 가입일: 10/30/23
197 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-4, Konn Fall 2023 UMass Dartmouth, Team 3-4, Konn Fall 2023 회원
UMASSD-KONN-F23S3G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 36
전체 시간: 179
