소개
If necessary, removing the CPU PCB allows for a complete reset of your Amazon Echo's memory. It is easy to remove and is the first step in disassembling the rest of the device.
After removing a few screws and the ribbon cable, a new CPU PCB can be inserted. Removing it only requires a spudger for the backing and a thin prying tool for disconnecting the ribbon cable.
필요한 것
Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
거의 끝나갑니다!
결론
