주요 콘텐츠로 건너뛰기
Amazon Echo Dot 5th Generation Ribbon Cable Replacement
필요한 것
  1. Amazon Echo Dot 5th Generation Ribbon Cable Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Amazon Echo Dot 5th Generation Ribbon Cable Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
  4. Amazon Echo Dot 5th Generation Ribbon Cable Replacement, Ribbon Cable: 4 단계, 이미지 1개 중 1개
    • Now, use a plastic prying tool to remove the ribbon cable from the speaker housing.
  5. Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Torx T8 bit, remove the four 1.25 cm screws around the edges of the speaker housing, and lift the housing off of the top case, revealing the switch PCB.
  6. Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Dot 5th Generation Ribbon Cable Replacement: 6 단계, 이미지 3개 중 3개
    • Use a plastic spudger to undo the adhesive attaching the ribbon cable to the top case. Then, flip the tab on the switch PCB, and slide out the ribbon cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jack Salmonson
회원 가입일: 10/30/23
190 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-4, Konn Fall 2023 UMass Dartmouth, Team 3-4, Konn Fall 2023 회원
UMASSD-KONN-F23S3G4
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 31
전체 시간: 484
