주요 콘텐츠로 건너뛰기
Amazon Echo Dot 5th Generation Speaker Replacement
필요한 것
  1. Amazon Echo Dot 5th Generation Speaker Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Amazon Echo Dot 5th Generation Speaker Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Speaker Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Dot 5th Generation Speaker Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Dot 5th Generation Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
  4. Amazon Echo Dot 5th Generation Speaker Replacement, Speaker: 4 단계, 이미지 1개 중 1개
    • To access the speaker, take a plastic spudger and slowly lift the ribbon off of the housing.
    • Remove the four T8 1cm Torx screws around the edges of the metal housing.
    • Lift the top case off of the housing to reveal the speaker.
  5. Amazon Echo Dot 5th Generation Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Torx T5 bit, remove the four 1cm screws around the speaker and slide it out of the housing.
    • Pull 2 speaker cables off of the speaker and detach it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Madison Dufault
회원 가입일: 10/30/23
112 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-4, Konn Fall 2023 UMass Dartmouth, Team 3-4, Konn Fall 2023 회원
UMASSD-KONN-F23S3G4
4 회원들
안내서 7개를 작성함
1가이드 댓글
Wo bekomme ich den Ersatzlautsprecher?
a.ableidinger@aon.at - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 23
지난 30일: 125
전체 시간: 1,718
