주요 콘텐츠로 건너뛰기
Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement
필요한 것
  1. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Motherboard: 1 단계, 이미지 1/2 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Motherboard: 1 단계, 이미지 2/2
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 2 단계, 이미지 1/1
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 3 단계, 이미지 1/3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 3 단계, 이미지 2/3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 3 단계, 이미지 3/3
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
  4. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Ribbon Cable: 4 단계, 이미지 1/1
    • Now, use a plastic prying tool to remove the ribbon cable from the speaker housing.
  5. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 5 단계, 이미지 1/1
    • Using the Torx T8 bit, remove the four 1.25 cm screws around the edges of the speaker housing, and lift the housing off of the top case, revealing the switch PCB.
  6. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 6 단계, 이미지 1/3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 6 단계, 이미지 2/3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: 6 단계, 이미지 3/3
    • Use a plastic spudger to undo the adhesive attaching the ribbon cable to the top case. Then, flip the tab on the switch PCB, and slide out the ribbon cable.
  7. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Switch PCB: 7 단계, 이미지 1/3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Switch PCB: 7 단계, 이미지 2/3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Switch PCB: 7 단계, 이미지 3/3
    • Remove the upper switch PCB using the T4 Torx bit to unscrew the four 5 mm screws.
    • The PCB is glued down in between the 4 buttons.
    • Push down on the buttons through the top of the case and pry lightly with plastic tools until loose, then remove.
결론
Catherinej
회원 가입일: 10/30/23
73 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-4, Konn Fall 2023 UMass Dartmouth, Team 3-4, Konn Fall 2023 회원
UMASSD-KONN-F23S3G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 30
전체 시간: 170
