소개
This guide demonstrates how to remove the LED/Microphone board. This board contains the LED indication ring at the top of the Echo, as well as the seven microphone array. This guide should assist you if the LED ring is malfunctioning or if the Echo has issues hearing you.
필요한 것
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
Where can i buy this LED/Microphone board for replacement?
