이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
이 단계에 사용된 도구:Tweezers$4.99-
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
Pull the two ribbon cables from their connectors on the motherboard.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 11개
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - 답글
