주요 콘텐츠로 건너뛰기
Amazon Echo Power and Speaker Driver Board Replacement
필요한 것
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: 1 단계, 이미지 1개 중 1개
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Power and Speaker Driver Board Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Power and Speaker Driver Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: 3 단계, 이미지 1개 중 1개
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Power and Speaker Driver Board Replacement: 5 단계, 이미지 2개 중 1개 Amazon Echo Power and Speaker Driver Board Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Power and Speaker Driver Board Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Power and Speaker Driver Board Replacement: 6 단계, 이미지 3개 중 3개
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alexander Albert
회원 가입일: 02/04/16
1,169 평판
안내서 6개를 작성함
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G3
4 회원들
안내서 12개를 작성함
22가이드 댓글
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - 답글
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
Where do I get a replacement board ?
Sean Burch - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 28
지난 30일: 154
전체 시간: 28,394
