주요 콘텐츠로 건너뛰기
소개
This guide shows how to replace the power and speaker driver board in the Amazon Echo. This board is responsible for delivering power to the various components of the Echo and also delivers the appropriate signals to the woofer and tweeter. This guide may prove helpful if your Echo has issues turning on, sounds distorted, or won't make any sound.
부품
지정된 부품이 없습니다.
  1. Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo. Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo. Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable. Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Using the spudger, pull back the two plastic clips on the plate. Lift the board up and pull it away from the plate. Lift the board up and pull it away from the plate.
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Alexander Albert
회원 가입일: 2016년 02월 04일
1,109 평판
안내서 6개 작성하였습니다
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G3
4 회원들
안내서 12개 작성하였습니다
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - 답글
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
Where do I get a replacement board ?
Sean Burch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 27
30일 전: 128
전체 시간: 22,511
