주요 콘텐츠로 건너뛰기
Amazon Echo Show 15 Back Panel Replacement
필요한 것
  1. Amazon Echo Show 15 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/3 Amazon Echo Show 15 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/3 Amazon Echo Show 15 Back Panel Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Back Panel Replacement: 2 단계, 이미지 1/3 Amazon Echo Show 15 Back Panel Replacement: 2 단계, 이미지 2/3 Amazon Echo Show 15 Back Panel Replacement: 2 단계, 이미지 3/3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
결론
Julia Silvestrin
회원 가입일: 09/20/23
228 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-4, McMurrin Fall 2023 Utah Tech University, Team 1-4, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 40
전체 시간: 210
