주요 콘텐츠로 건너뛰기
Amazon Echo Show 15 Inner Black Panel Replacement
필요한 것
  1. Amazon Echo Show 15 Inner Black Panel Replacement, Back Panel: 1 단계, 이미지 1/3 Amazon Echo Show 15 Inner Black Panel Replacement, Back Panel: 1 단계, 이미지 2/3 Amazon Echo Show 15 Inner Black Panel Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Inner Black Panel Replacement: 2 단계, 이미지 1/3 Amazon Echo Show 15 Inner Black Panel Replacement: 2 단계, 이미지 2/3 Amazon Echo Show 15 Inner Black Panel Replacement: 2 단계, 이미지 3/3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
  3. Amazon Echo Show 15 Inner Black Panel Replacement, Inner Black Panel: 3 단계, 이미지 1/3 Amazon Echo Show 15 Inner Black Panel Replacement, Inner Black Panel: 3 단계, 이미지 2/3 Amazon Echo Show 15 Inner Black Panel Replacement, Inner Black Panel: 3 단계, 이미지 3/3
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
결론
Talara
회원 가입일: 09/20/23
306 평판
안내서 3개 작성하였습니다
Utah Tech University, Team 1-4, McMurrin Fall 2023 Utah Tech University, Team 1-4, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 85
