소개
If your Amazon Echo Show 15 (model H6Y2A5) is plagued by software malfunctions or features a non-functional motherboard, use this guide for comprehensive motherboard replacement.
The motherboard plays a critical role in the overall functionality of the Echo Show 15, and addressing software issues may necessitate a replacement.
Before starting the motherboard replacement, ensure your device is powered off completely and disconnected from any external power sources. This guide provides step-by-step instructions on how to replace the motherboard, allowing you to restore your Amazon Echo Show 15 to optimal performance.
필요한 것
Remove the four white stickers on your device's back panel.
Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
Take off the metal protector.
Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
