주요 콘텐츠로 건너뛰기
Amazon Echo Show 15 Motherboard Replacement
필요한 것
  1. Amazon Echo Show 15 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: 1 단계, 이미지 2/3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Motherboard Replacement: 2 단계, 이미지 1/3 Amazon Echo Show 15 Motherboard Replacement: 2 단계, 이미지 2/3 Amazon Echo Show 15 Motherboard Replacement: 2 단계, 이미지 3/3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
  3. Amazon Echo Show 15 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
    • Take off the metal protector.
    • The metal protector is connected to the motherboard with adhesive. More force may be necessary.
    • Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
  4. Amazon Echo Show 15 Motherboard Replacement: 4 단계, 이미지 1/3 Amazon Echo Show 15 Motherboard Replacement: 4 단계, 이미지 2/3 Amazon Echo Show 15 Motherboard Replacement: 4 단계, 이미지 3/3
    • Detach the connectors for the camera and buttons from the motherboard.
    • Detach the connectors for the power station and speakers from the motherboard.
    • Detach the small white coaxial cables from the motherboard.
    • These connectors will be reused, so be very careful with them. The small white connectors come off by being pulled up.
  5. Amazon Echo Show 15 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the motherboard from the main device.
결론
Paysen Hudson
회원 가입일: 09/20/23
181 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-4, McMurrin Fall 2023 Utah Tech University, Team 1-4, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 27
전체 시간: 233
