소개
Follow this guide to replace the Amazon Echo Show Display. The display is especially susceptible to damage because of its exposed nature.
필요한 것
Orient the Amazon Echo Show 5 so that the display is face down.
Use a spudger to remove the grey bottom cover.
Remove the red and black power connector connecting to the motherboard with either a prying tool or your hands.
Orient the Amazon Echo Show 5 so that the display is facing up.
Apply heat to the edges of the display using a heat gun.
다른 한 분이 해당 안내서를 완성하였습니다.
