주요 콘텐츠로 건너뛰기
Amazon Echo Show 5 I/O Board Replacement
필요한 것
  1. Amazon Echo Show 5 I/O Board Replacement, Amazon Echo Show 5 Disassembly: 1 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement, Amazon Echo Show 5 Disassembly: 1 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement, Amazon Echo Show 5 Disassembly: 1 단계, 이미지 3/3
    • Power off and unplug the Amazon Echo Show 5. Failure to do so could result in injury or damage to the device.
    • Orient the Amazon Echo Show 5 so that the display is face down.
    • Use a spudger to remove the grey bottom cover.
    • During reassembly, adhesive needs to be applied to secure the bottom cover.
  2. Amazon Echo Show 5 I/O Board Replacement: 2 단계, 이미지 1/2 Amazon Echo Show 5 I/O Board Replacement: 2 단계, 이미지 2/2
    • Remove the three screws with a T6 Torx screwdriver.
  3. Amazon Echo Show 5 I/O Board Replacement: 3 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement: 3 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement: 3 단계, 이미지 3/3
    • Use a spudger to release the six internal tabs lining the sides of the device.
    • There are fragile ribbon connectors along the side of the screen with the camera on it. So, do not stick the spudger more than a couple millimeters into the device.
  4. Amazon Echo Show 5 I/O Board Replacement: 4 단계, 이미지 1/1
    • Carefully open the device by folding it open along the top edge where the camera is located.
    • Do not try to open the device from any other side as this would damage the ribbon connectors.
  5. Amazon Echo Show 5 I/O Board Replacement, Speaker: 5 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement, Speaker: 5 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement, Speaker: 5 단계, 이미지 3/3
    • Carefully disconnect the red and black power connector.
  6. Amazon Echo Show 5 I/O Board Replacement: 6 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement: 6 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement: 6 단계, 이미지 3/3
    • Remove the three ZIF connector ribbon cables that connect the speaker housing to the display housing.
    • Do not pull ribbon cables straight out, as this will damage the device. To safely remove ribbon cables, pull up on the tab where the cable is going into.
  7. Amazon Echo Show 5 I/O Board Replacement: 7 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement: 7 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement: 7 단계, 이미지 3/3
    • Remove the four screws securing the speaker using a T6 Torx screwdriver.
  8. Amazon Echo Show 5 I/O Board Replacement: 8 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement: 8 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement: 8 단계, 이미지 3/3
    • Pull back the silver tape.
  9. Amazon Echo Show 5 I/O Board Replacement: 9 단계, 이미지 1/1
    • Carefully pull out the speaker housing from the black ledge.
  10. Amazon Echo Show 5 I/O Board Replacement, I/O Board: 10 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement, I/O Board: 10 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement, I/O Board: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to peel off the metallic tape from the I/O board.
  11. Amazon Echo Show 5 I/O Board Replacement: 11 단계, 이미지 1/3 Amazon Echo Show 5 I/O Board Replacement: 11 단계, 이미지 2/3 Amazon Echo Show 5 I/O Board Replacement: 11 단계, 이미지 3/3
    • Use the T6 Torx screwdriver to remove the two screws.
  12. Amazon Echo Show 5 I/O Board Replacement: 12 단계, 이미지 1/2 Amazon Echo Show 5 I/O Board Replacement: 12 단계, 이미지 2/2
    • Lift the board so that the ribbon cable is easily accessible.
    • Try not to use too much force as this may damage the ribbon cable.
  13. Amazon Echo Show 5 I/O Board Replacement: 13 단계, 이미지 1/2 Amazon Echo Show 5 I/O Board Replacement: 13 단계, 이미지 2/2
    • Disconnect the single ribbon cable.
    • Carefully pull out the I/O board.
결론
David Degbor
회원 가입일: 10/26/22
277 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-4, Petersen Fall 2022 UMass Dartmouth, Team 2-4, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 410
