주요 콘텐츠로 건너뛰기
Amazon Echo Show 5 Motherboard Replacement
필요한 것
  1. Amazon Echo Show 5 Motherboard Replacement, Amazon Echo Show 5 Disassembly: 1 단계, 이미지 1/3 Amazon Echo Show 5 Motherboard Replacement, Amazon Echo Show 5 Disassembly: 1 단계, 이미지 2/3 Amazon Echo Show 5 Motherboard Replacement, Amazon Echo Show 5 Disassembly: 1 단계, 이미지 3/3
    • Power off and unplug the Amazon Echo Show 5. Failure to do so could result in injury or damage to the device.
    • Orient the Amazon Echo Show 5 so that the display is face down.
    • Use a spudger to remove the grey bottom cover.
    • During reassembly, adhesive needs to be applied to secure the bottom cover.
  2. Amazon Echo Show 5 Motherboard Replacement: 2 단계, 이미지 1/2 Amazon Echo Show 5 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the three screws with a T6 Torx screwdriver.
  3. Amazon Echo Show 5 Motherboard Replacement: 3 단계, 이미지 1/3 Amazon Echo Show 5 Motherboard Replacement: 3 단계, 이미지 2/3 Amazon Echo Show 5 Motherboard Replacement: 3 단계, 이미지 3/3
    • Use a spudger to release the six internal tabs lining the sides of the device.
    • There are fragile ribbon connectors along the side of the screen with the camera on it. So, do not stick the spudger more than a couple millimeters into the device.
  4. Amazon Echo Show 5 Motherboard Replacement: 4 단계, 이미지 1/1
    • Carefully open the device by folding it open along the top edge where the camera is located.
    • Do not try to open the device from any other side as this would damage the ribbon connectors.
  5. Amazon Echo Show 5 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the red and black power connector connecting to the motherboard with either a prying tool or your hands.
  6. Amazon Echo Show 5 Motherboard Replacement: 6 단계, 이미지 1/2 Amazon Echo Show 5 Motherboard Replacement: 6 단계, 이미지 2/2
    • Disconnect the five ribbon cables connecting to the motherboard.
    • To disconnect the cables, use the tip of a prying tool, or your fingernail, to flip up the small locking flap. Then, you can safely pull the cable out.
    • Be sure to pry up the hinged flap, not the connector socket.
    • There is a white line on the ribbon connectors that indicates the edge of the connection area. To reinstall, insert the connector up to this white line and close the flap. If the white line is clearly visible after closing the flap, it is probably misaligned and needs to be repositioned.
  7. Amazon Echo Show 5 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the six 4 mm screws that are used to hold down the motherboard using a T6 Security Torx Screwdriver.
  8. Amazon Echo Show 5 Motherboard Replacement: 8 단계, 이미지 1/2 Amazon Echo Show 5 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift the motherboard up and out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zachary Buckler
회원 가입일: 10/26/22
598 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-4, Petersen Fall 2022 UMass Dartmouth, Team 2-4, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G4
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
What is the mainchip/soc?
Cason Shen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 36
전체 시간: 587
