주요 콘텐츠로 건너뛰기
Amazon Echo Show 8 2nd Generation Rear Case Replacement
필요한 것
  1. Amazon Echo Show 8 2nd Generation Rear Case Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Rear Case Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Rear Case Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Rear Case Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Rear Case Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Rear Case Replacement: 2 단계, 이미지 3개 중 3개
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Rear Case Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Rear Case Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Rear Case Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Rear Case Replacement: 4 단계, 이미지 3개 중 1개 Amazon Echo Show 8 2nd Generation Rear Case Replacement: 4 단계, 이미지 3개 중 2개 Amazon Echo Show 8 2nd Generation Rear Case Replacement: 4 단계, 이미지 3개 중 3개
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
결론
작성자
3다른 기여자 명과 함께
Brian Le
회원 가입일: 02/14/24
681 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 52
전체 시간: 640
