소개
If your Amazon Echo Show's audio is crackly or muffled, you might need to replace the speakers. Follow the prerequisite guide listed at the top--"Opening The Show". This guide tells you how to open up the device so you can access the speakers.
Before starting this guide, gather a T4, T5, and T6 Torx screwdriver. Steps requiring a tweezer can instead be used with your hands carefully.
필요한 것
Use a non-magnetic T-6 screwdriver to unscrew the four 6mm screws on the speaker mount.
Repeat this step for the other speaker.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Seems you missed an important step on here. How do you get the front off the box? Show how to remove the speaker grill, the grill cloth and then pry up the digitizer and screen. That’s where all the f***ing screws are!!! That’s how you get into this damned thing!! But you left all that ‘unimportant’ stuff out.
Where do you get a replacement speakers
bluwolf224 - 답글
