주요 콘텐츠로 건너뛰기
Amazon Echo Studio Motherboard Replacement
필요한 것
  1. Amazon Echo Studio Motherboard Replacement, Power Supply Board: 1 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement, Power Supply Board: 1 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement, Power Supply Board: 1 단계, 이미지 3개 중 3개
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
  3. Amazon Echo Studio Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Studio Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
  5. Amazon Echo Studio Motherboard Replacement, Subwoofer: 5 단계, 이미지 1개 중 1개
    • Remove the two screws located across from each other on the outside of the plastic ring shown.
    • Remove the plastic outer ring that hugs the inside of the edges of the device.
    • This may require you to use a soft prying tool to separate it from the outer shell.
  6. Amazon Echo Studio Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
    • Once the screws are removed, take the power supply's baseplate out of the unit.
    • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
  7. Amazon Echo Studio Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Amazon Echo Studio Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
    • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
    • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
    • Your subwoofer is now disconnected and ready to be replaced.
  8. Amazon Echo Studio Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Amazon Echo Studio Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Remove the thirteen 9 mm Phillips #00 screws.
    • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
  9. Amazon Echo Studio Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
    • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
  10. Amazon Echo Studio Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
  11. Amazon Echo Studio Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the motherboard from the device by pulling it out.
    • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
결론
작성자
2다른 기여자 명과 함께
Colin Nicoll
회원 가입일: 10/26/22
109 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G6
4 회원들
안내서 7개를 작성함
6가이드 댓글
where can I buy a motherboard replacement ?
Juan Daniel Hernandez R - 답글
I also would like to know where to get a motherboard... my studio is stuck at the green ring.
Ed Wilcox - 답글
i also would like to know. mine stuck with cyan circle
Алексей - 답글
Is there any place to buy the Amazon Echo Studio Motherboard?
DOCA - 답글
hi is there a place to buy this motherboard?
Bede Bede - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 60
전체 시간: 1,831
