주요 콘텐츠로 건너뛰기
Amazon Echo Studio Power Supply Board Replacement
필요한 것
  1. Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: 1 단계, 이미지 3개 중 1개 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: 1 단계, 이미지 3개 중 2개 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: 1 단계, 이미지 3개 중 3개
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Power Supply Board Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Studio Power Supply Board Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Studio Power Supply Board Replacement: 2 단계, 이미지 3개 중 3개
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
  3. Amazon Echo Studio Power Supply Board Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Studio Power Supply Board Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Studio Power Supply Board Replacement: 3 단계, 이미지 3개 중 3개
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Power Supply Board Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Studio Power Supply Board Replacement: 4 단계, 이미지 2개 중 2개
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nick Saranich
회원 가입일: 10/24/22
297 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G6
4 회원들
안내서 7개를 작성함
14가이드 댓글
Thank you for this guide. It was very easy operation, but I believe problem with Echo is that its impossible to get spare parts?
My Echo Studio is in short circuit state.
https://ibb.co/kqTXw0w
https://ibb.co/zV4KH6y
https://ibb.co/GMgPDDY
https://ibb.co/4PMZjDj
https://ibb.co/k0MsFPM
Kertalaaki - 답글
Taking this thing apart really is easy. Thanks for the tip on how to get started. But as Kertalaaki figured, it seems there is no chance to get replacement parts. I guess Amazon prefers to sell new devices instead of having people repair their Studio device. I have a similar problem Kertalaaki describes. Whenever I plug the device in, it causes the breaker to blow. Now having the device in hand, I can't see any obvious damage as Kertalaakis photos show, but I still would like to get me a new power supply board. If anyone has any ideas on how to get one, please share! Thanks a lot in advance!
Ingo Gambin - 답글
Same Problem like Ingo and Kertalaaki. Did anyone figure out how to get a new power supply?
Martin Dirr - 답글
I contacted the Amazon regarding the matter, and spare parts are not available. The solution from their side was a credit towards a new device with a discount. Spare parts are not available.
Kertalaaki - 답글
The power source is custom built just for this implementation and there is nothing similar on the market as far I have found.
Kertalaaki - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 164
전체 시간: 2,372
