주요 콘텐츠로 건너뛰기
Amazon Fire 5th Generation Speaker Replacement
필요한 것
  1. Amazon Fire 5th Generation Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Amazon Fire 5th Generation Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
    • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
    • Then, remove the back cover from the device.
  2. Amazon Fire 5th Generation Speaker Replacement: 2 단계, 이미지 1/2 Amazon Fire 5th Generation Speaker Replacement: 2 단계, 이미지 2/2
    • Pry the speaker from the case using the iFixit Opening Tool.
    • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
    • Be careful not to pull the speaker wires from the motherboard.
  3. Amazon Fire 5th Generation Speaker Replacement: 3 단계, 이미지 1/3 Amazon Fire 5th Generation Speaker Replacement: 3 단계, 이미지 2/3 Amazon Fire 5th Generation Speaker Replacement: 3 단계, 이미지 3/3
    This step is completely unnecessary. The cords don't get in the way of the rest of the procedure. Feel free to disregard this step.
    Jacob Dayley - 답글
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amber Bunch
회원 가입일: 02/10/16
1,381 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-2, Nance Spring 2016 USF Tampa, Team 1-2, Nance Spring 2016 회원
USFT-NANCE-S16S1G2
3 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,157
