주요 콘텐츠로 건너뛰기
Amazon Fire Game Controller Outer Shell Replacement
필요한 것
  1. Amazon Fire Game Controller Outer Shell Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
  2. Amazon Fire Game Controller Outer Shell Replacement: 2 단계, 이미지 1/1
    • Pry the two shell pieces from one another from the top orientation with a plastic opening tool.
    • The weights will fall out.
  3. Amazon Fire Game Controller Outer Shell Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery terminal wires and the play, pause, and stop wires from the motherboard.
  4. Amazon Fire Game Controller Outer Shell Replacement: 4 단계, 이미지 1/1
    • Use a J1 screwdriver to unscrew the four 7 mm screws from the motherboard.
  5. Amazon Fire Game Controller Outer Shell Replacement: 5 단계, 이미지 1/1
    • Lift the motherboard out of the controller casing.
  6. Amazon Fire Game Controller Outer Shell Replacement, Outer Shell: 6 단계, 이미지 1/1
    • Use a JIS #0 screwdriver to remove the two 7 mm screws from the retaining bracket that secures the play, stop, and pause button wiring.
  7. Amazon Fire Game Controller Outer Shell Replacement: 7 단계, 이미지 1/1
    • Use a JIS #0 screwdriver to unscrew the 5 mm screws from the LED indicator assembly.
  8. Amazon Fire Game Controller Outer Shell Replacement: 8 단계, 이미지 1/2 Amazon Fire Game Controller Outer Shell Replacement: 8 단계, 이미지 2/2
    • Slide out the triggers and bumpers.
결론
Andrew Klopfenstein
회원 가입일: 01/14/19
19 평판
안내서 2개 작성하였습니다
IUPUI, Team S4-G4, Wilson Summer 2019 IUPUI, Team S4-G4, Wilson Summer 2019 회원
IUPUI-WILSON-SU19S4G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 9
전체 시간: 588
