주요 콘텐츠로 건너뛰기
Amazon Fire HD 10 Battery Replacement
필요한 것
  1. Amazon Fire HD 10 Battery Replacement, Screen: 1 단계, 이미지 1/3 Amazon Fire HD 10 Battery Replacement, Screen: 1 단계, 이미지 2/3 Amazon Fire HD 10 Battery Replacement, Screen: 1 단계, 이미지 3/3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
    The right side with the power switch on top?
    Sonny Shear - 답글
    Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
    Thanks!
    Steve Ciciora - 답글
  2. Amazon Fire HD 10 Battery Replacement: 2 단계, 이미지 1/1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
    What is a ZIP connector? What does it look like?
    Beldenr - 답글
    Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
    Adam O'Camb -
  3. Amazon Fire HD 10 Battery Replacement: 3 단계, 이미지 1/2 Amazon Fire HD 10 Battery Replacement: 3 단계, 이미지 2/2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Battery Replacement, Battery: 5 단계, 이미지 1/3 Amazon Fire HD 10 Battery Replacement, Battery: 5 단계, 이미지 2/3 Amazon Fire HD 10 Battery Replacement, Battery: 5 단계, 이미지 3/3
    • Locate the power cable that links the battery to the motherboard.
    • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
    • The third image shows what it should look like with the battery power cable is disconnected.
    Battery removal is optional for the motherboard, but is a great addition to this guide for completeness.
    scottpickles - 답글
  6. Amazon Fire HD 10 Battery Replacement: 6 단계, 이미지 1/3 Amazon Fire HD 10 Battery Replacement: 6 단계, 이미지 2/3 Amazon Fire HD 10 Battery Replacement: 6 단계, 이미지 3/3
    • Begin by locating the double sided pull tape locations.
    • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
    • Pull the black soft tabs to release the tape's adhesion.
    • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
    • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
    Why not heating the tabs a little to take battery easier
    Engin Isleyen - 답글
  7. Amazon Fire HD 10 Battery Replacement: 7 단계, 이미지 1/3 Amazon Fire HD 10 Battery Replacement: 7 단계, 이미지 2/3 Amazon Fire HD 10 Battery Replacement: 7 단계, 이미지 3/3
    • Make sure all the adhesive is removed before trying to lift the battery from the case.
    • After the battery is totally free of any adhesion, simply lift the battery from the case.
  8. Amazon Fire HD 10 Battery Replacement: 8 단계, 이미지 1/3 Amazon Fire HD 10 Battery Replacement: 8 단계, 이미지 2/3 Amazon Fire HD 10 Battery Replacement: 8 단계, 이미지 3/3
    • Inspect battery for any leakage.
    • Please follow all U.S. regulations and laws when disposing or recycling the battery.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Jaie Hillery
회원 가입일: 10/07/14
1,718 평판
안내서 10개 작성하였습니다
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G6
3 회원들
안내서 22개 작성하였습니다
댓글 8개
why is there so much empty space next to the battery?
echow2001 - 답글
Big screen, little processor. The screen dictates the space, that’s why the battery has to be secured with adhesive.
ctgblue -
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
tyger.night - 답글
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
ctgblue -
How do you know if ita battery or charging port? Mine dont do anything whe. Its
Tech Reviews - 답글
That’s my question also. How do you know if it is the battery or the port?
ronvir5049 - 답글
Fitted battery replacement now won't start up any clues where iv gone wrong?
steve cruickshanks - 답글
This is amazing, my mom and dad won't have to spend money on buying a new tablet and I get to save my tablet witch has Malayalam memory's for me even though it sucks (just I gotta save up for the tools)
Alex Qwes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 86
30일 전: 461
전체 시간: 42,112
