소개
You will need to use the screen replacement guide as a prerequisite.
필요한 것
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
The right side with the power switch on top?
Sonny Shear - 답글
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - 답글
