주요 콘텐츠로 건너뛰기
Amazon Fire HD 10 Rear Facing Camera Replacement
필요한 것
  1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: 1 단계, 이미지 1/3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: 1 단계, 이미지 2/3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: 1 단계, 이미지 3/3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Rear Facing Camera Replacement: 2 단계, 이미지 1/1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Rear Facing Camera Replacement: 3 단계, 이미지 1/2 Amazon Fire HD 10 Rear Facing Camera Replacement: 3 단계, 이미지 2/2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Rear Facing Camera Replacement: 4 단계, 이미지 1/1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: 5 단계, 이미지 1/2 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: 5 단계, 이미지 2/2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  6. Amazon Fire HD 10 Rear Facing Camera Replacement: 6 단계, 이미지 1/2 Amazon Fire HD 10 Rear Facing Camera Replacement: 6 단계, 이미지 2/2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  7. Amazon Fire HD 10 Rear Facing Camera Replacement: 7 단계, 이미지 1/2 Amazon Fire HD 10 Rear Facing Camera Replacement: 7 단계, 이미지 2/2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jaie Hillery
회원 가입일: 10/07/14
1,685 평판
안내서 10개 작성하였습니다
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G6
3 회원들
안내서 22개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 788
