주요 콘텐츠로 건너뛰기
Amazon Fire HD 10 Screen Replacement
필요한 것
  1. Amazon Fire HD 10 Screen Replacement, Screen: 1 단계, 이미지 1/3 Amazon Fire HD 10 Screen Replacement, Screen: 1 단계, 이미지 2/3 Amazon Fire HD 10 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: 2 단계, 이미지 1/1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: 3 단계, 이미지 1/2 Amazon Fire HD 10 Screen Replacement: 3 단계, 이미지 2/2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the screen and digitizer from the case completely.
결론
다른 27명이 해당 안내서를 완성하였습니다.
Jaie Hillery
회원 가입일: 10/07/14
1,718 평판
안내서 10개 작성하였습니다
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G6
3 회원들
안내서 22개 작성하였습니다
댓글 16개
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - 답글
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - 답글
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - 답글
What is needed to attach the screen back to the case?
Jimmy Lee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 65
30일 전: 258
전체 시간: 35,520
