주요 콘텐츠로 건너뛰기
Amazon Fire HD 10 USB Charging Port Replacement
필요한 것
동영상 지침
결론
To reassemble your device, follow these instructions in reverse order. Be sure connection pins (in the center of the pad) have enough solder to reattach the the replacement micro-usb.
다른 12명이 해당 안내서를 완성하였습니다.
eCuration
회원 가입일: 05/19/17
376,693 평판
안내서 234개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 3개
Can you use usb replacement parts for fire hd 6, 7 and 8.9 for the fire hd 10?
custmadehancraf - 답글
Some English narration instead of the annoying music would be useful. Unsoldering looked rather magical, what was the heat source? Hot air gun under the board? You’re daubing on cleaner and flux, I guess, no idea what’s what. Paste solder?
Alan Corey - 답글
Is there a way to know if it's the battery or the charging port
Tech Reviews - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 26
전체 시간: 14,713
