주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire HD 3rd Gen Disassembly
필요한 것
  1. Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: 1 단계, 이미지 3개 중 1개 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: 1 단계, 이미지 3개 중 2개 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: 1 단계, 이미지 3개 중 3개
    • Using a Jimmy, start at the volume control and work your way around by prying off the back and then lifting it back like a book.
  2. Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: 2 단계, 이미지 3개 중 1개 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: 2 단계, 이미지 3개 중 2개 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: 2 단계, 이미지 3개 중 3개
    • Peel off the 2 yellow pieces of yellow tape on the battery.
  3. Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: 3 단계, 이미지 3개 중 1개 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: 3 단계, 이미지 3개 중 2개 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: 3 단계, 이미지 3개 중 3개
    • Take off all the ribbon cables connected to the main board. (Marked in Red)
    • On the 2 speakers marked in yellow, be sure to pull straight up. Then unclip the speaker cables.
  4. Amazon Fire HD 3rd Gen Disassembly, Unscrew speakers and gray bracket: 4 단계, 이미지 1개 중 1개
    • Using a T4 Torx driver, unscrew each of the 2 screws holding in the 2 speakers. (red)
    • Then, take out the 7 screws hold in the gray bracket (yellow)
    • Now, unscrew the 8 screws holding the motherboard. (green)
  5. Amazon Fire HD 3rd Gen Disassembly, Unscrew the I/O: 5 단계, 이미지 1개 중 1개
    • Next, use a T4 Torx Screwdriver again to unscrew the headphone jack and the Micro USB port.
  6. Amazon Fire HD 3rd Gen Disassembly, Take everything out.: 6 단계, 이미지 1개 중 1개
    • 1. Remove the Headphone and USB ports.
    • 2. Remove motherboard.
    • 3. Remove the speakers.
    • 4. Remove gray bracket with battery.
  7. Amazon Fire HD 3rd Gen Disassembly, Remove the screen.: 7 단계, 이미지 1개 중 1개
    • Now, using a T4, unscrew the 4 screws holding in the screen.
  8. Amazon Fire HD 3rd Gen Disassembly, Your Done!: 8 단계, 이미지 1개 중 1개
    • Congrats! Now follow the directions in reverse to reassemble your Fire!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Cooper Anderson
회원 가입일: 09/08/17
541 평판
안내서 2개를 작성함
1가이드 댓글
Please where can I get the digitizer?
Mine is shattered and I haven't used it for over 3years but I can still power it up.
Will very much appreciate a lead.
Patrick,
Nigeria
Patrick Mordi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 25
전체 시간: 1,999
