주요 콘텐츠로 건너뛰기
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
필요한 것
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: 1 단계, 이미지 1/3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: 1 단계, 이미지 2/3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: 1 단계, 이미지 3/3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 2 단계, 이미지 1/1
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 3 단계, 이미지 1/1
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 4 단계, 이미지 1/2 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 4 단계, 이미지 2/2
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
결론
Omir Rosado
회원 가입일: 09/30/16
725 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-4, Passmore Fall 2016 USF Tampa, Team 4-4, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 591
