주요 콘텐츠로 건너뛰기
Amazon Fire HD 8 Bottom Speaker Replacement
필요한 것
  1. Amazon Fire HD 8 Bottom Speaker Replacement, Screen: 1 단계, 이미지 1/2 Amazon Fire HD 8 Bottom Speaker Replacement, Screen: 1 단계, 이미지 2/2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Bottom Speaker Replacement: 2 단계, 이미지 1/1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Bottom Speaker Replacement: 3 단계, 이미지 1/3 Amazon Fire HD 8 Bottom Speaker Replacement: 3 단계, 이미지 2/3 Amazon Fire HD 8 Bottom Speaker Replacement: 3 단계, 이미지 3/3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Bottom Speaker Replacement: 4 단계, 이미지 1/3 Amazon Fire HD 8 Bottom Speaker Replacement: 4 단계, 이미지 2/3 Amazon Fire HD 8 Bottom Speaker Replacement: 4 단계, 이미지 3/3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Bottom Speaker Replacement, Bottom Speaker: 5 단계, 이미지 1/1
    • Using tweezers, carefully lift the copper strip from the right side of the speaker.
  6. Amazon Fire HD 8 Bottom Speaker Replacement: 6 단계, 이미지 1/2 Amazon Fire HD 8 Bottom Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the two screws located on the top left and bottom right of the speaker using a T4 screwdriver.
  7. Amazon Fire HD 8 Bottom Speaker Replacement: 7 단계, 이미지 1/1
    • Lift the right side of the speaker and carefully unhook and remove it from the device.
    • Be mindful of the white wire connecting the speaker to the device.
  8. Amazon Fire HD 8 Bottom Speaker Replacement: 8 단계, 이미지 1/2 Amazon Fire HD 8 Bottom Speaker Replacement: 8 단계, 이미지 2/2
    • Set aside the black speaker and follow the white wire to its connection on the upper left side of the motherboard.
    • Using tweezers, gently pry the black clip upward from the board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marisa Holste
회원 가입일: 02/24/16
677 평판
안내서 1개 작성함
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G3
4 회원들
안내서 17개 작성하였습니다
댓글 한 개
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
Keven Paxton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 40
전체 시간: 4,159
