소개
In this guide, we will show you how to replace the speaker on the bottom left of the device. Before you start, make sure your device is powered off.
필요한 것
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
Using tweezers, carefully lift the copper strip from the right side of the speaker.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
