주요 콘텐츠로 건너뛰기
Amazon Fire HD 8 Front Camera Replacement
필요한 것
  1. Amazon Fire HD 8 Front Camera Replacement, Screen: 1 단계, 이미지 1/2 Amazon Fire HD 8 Front Camera Replacement, Screen: 1 단계, 이미지 2/2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Front Camera Replacement: 2 단계, 이미지 1/1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Front Camera Replacement: 3 단계, 이미지 1/3 Amazon Fire HD 8 Front Camera Replacement: 3 단계, 이미지 2/3 Amazon Fire HD 8 Front Camera Replacement: 3 단계, 이미지 3/3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Front Camera Replacement: 4 단계, 이미지 1/3 Amazon Fire HD 8 Front Camera Replacement: 4 단계, 이미지 2/3 Amazon Fire HD 8 Front Camera Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Front Camera Replacement, Front Camera: 5 단계, 이미지 1/3 Amazon Fire HD 8 Front Camera Replacement, Front Camera: 5 단계, 이미지 2/3 Amazon Fire HD 8 Front Camera Replacement, Front Camera: 5 단계, 이미지 3/3
    • Using a T4 screwdriver, remove the two screws situated on the left and right side of the camera.
    • The gasket may pop out, but it can easily be put back in.
  6. Amazon Fire HD 8 Front Camera Replacement: 6 단계, 이미지 1/2 Amazon Fire HD 8 Front Camera Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, gently remove the white tape with the QR code.
    • Fold the camera back and use tweezers to gently remove the orange tab.
결론
Dan Shimkus
회원 가입일: 02/24/16
1,184 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G3
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 17
전체 시간: 1,775
