주요 콘텐츠로 건너뛰기
Amazon Fire HD 8 Rear-facing Camera Replacement
필요한 것
  1. Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: 1 단계, 이미지 1/2 Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: 1 단계, 이미지 2/2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Rear-facing Camera Replacement: 2 단계, 이미지 1/1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Rear-facing Camera Replacement: 3 단계, 이미지 1/3 Amazon Fire HD 8 Rear-facing Camera Replacement: 3 단계, 이미지 2/3 Amazon Fire HD 8 Rear-facing Camera Replacement: 3 단계, 이미지 3/3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Rear-facing Camera Replacement: 4 단계, 이미지 1/3 Amazon Fire HD 8 Rear-facing Camera Replacement: 4 단계, 이미지 2/3 Amazon Fire HD 8 Rear-facing Camera Replacement: 4 단계, 이미지 3/3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: 5 단계, 이미지 1/2 Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: 5 단계, 이미지 2/2
    • Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
  6. Amazon Fire HD 8 Rear-facing Camera Replacement: 6 단계, 이미지 1/2 Amazon Fire HD 8 Rear-facing Camera Replacement: 6 단계, 이미지 2/2
    • Flip up the tab on the ZIF connector at the end of the ribbon cable.
    • Grasp the underside of the orange cable with the tweezers and gently slide the camera out of the connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alyssa Barrack
회원 가입일: 02/24/16
855 평판
안내서 1개 작성함
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G3
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 15
전체 시간: 1,989
