소개
In this guide, we will show you how to replace the rear-facing camera. Before you start, make sure your device is powered off.
필요한 것
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
