주요 콘텐츠로 건너뛰기
Amazon Fire HD 8 Screen Replacement
필요한 것
  1. Amazon Fire HD 8 Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Amazon Fire HD 8 Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Screen Replacement: 3 단계, 이미지 3개 중 1개 Amazon Fire HD 8 Screen Replacement: 3 단계, 이미지 3개 중 2개 Amazon Fire HD 8 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Screen Replacement: 4 단계, 이미지 3개 중 1개 Amazon Fire HD 8 Screen Replacement: 4 단계, 이미지 3개 중 2개 Amazon Fire HD 8 Screen Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Dan Shimkus
회원 가입일: 02/24/16
1,226 평판
안내서 3개를 작성함
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G3
4 회원들
안내서 17개를 작성함
19가이드 댓글
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - 답글
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber -
Fingers crossed Amazon offers more parts in the future! :)
Kelsea Weber -
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 47
지난 30일: 244
전체 시간: 75,165
