주요 콘텐츠로 건너뛰기
Amazon Fire Phone Micro-USB Port Replacement
필요한 것
  1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: 1 단계, 이미지 1개 중 1개
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: 2 단계, 이미지 3개 중 1개 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: 2 단계, 이미지 3개 중 2개 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: 2 단계, 이미지 3개 중 3개
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Micro-USB Port Replacement: 3 단계, 이미지 3개 중 1개 Amazon Fire Phone Micro-USB Port Replacement: 3 단계, 이미지 3개 중 2개 Amazon Fire Phone Micro-USB Port Replacement: 3 단계, 이미지 3개 중 3개
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: 4 단계, 이미지 1개 중 1개
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: 5 단계, 이미지 1개 중 1개
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
  6. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: 6 단계, 이미지 2개 중 1개 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: 6 단계, 이미지 2개 중 2개
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Micro-USB Port Replacement: 7 단계, 이미지 3개 중 1개 Amazon Fire Phone Micro-USB Port Replacement: 7 단계, 이미지 3개 중 2개 Amazon Fire Phone Micro-USB Port Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Micro-USB Port Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Micro-USB Port Replacement: 9 단계, 이미지 3개 중 1개 Amazon Fire Phone Micro-USB Port Replacement: 9 단계, 이미지 3개 중 2개 Amazon Fire Phone Micro-USB Port Replacement: 9 단계, 이미지 3개 중 3개
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Micro-USB Port Replacement: 10 단계, 이미지 2개 중 1개 Amazon Fire Phone Micro-USB Port Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
  11. Amazon Fire Phone Micro-USB Port Replacement: 11 단계, 이미지 1개 중 1개
    • Lift off bottom plastic piece with flat antenna cables
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kent Kawahara
회원 가입일: 10/01/15
110 평판
안내서 1개를 작성함
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 회원
CPSU-MANESS-F15S5G7
5 회원들
안내서 10개를 작성함
2가이드 댓글
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 2,517
