주요 콘텐츠로 건너뛰기
Amazon Fire TV Cube Motherboard Replacement
필요한 것
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: 1 단계, 이미지 1/3 Amazon Fire TV Cube Motherboard Replacement, Speaker: 1 단계, 이미지 2/3 Amazon Fire TV Cube Motherboard Replacement, Speaker: 1 단계, 이미지 3/3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: 2 단계, 이미지 1/3 Amazon Fire TV Cube Motherboard Replacement: 2 단계, 이미지 2/3 Amazon Fire TV Cube Motherboard Replacement: 2 단계, 이미지 3/3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: 3 단계, 이미지 1/1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: 4 단계, 이미지 1/2 Amazon Fire TV Cube Motherboard Replacement: 4 단계, 이미지 2/2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Amazon Fire TV Cube Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: 6 단계, 이미지 1/2 Amazon Fire TV Cube Motherboard Replacement: 6 단계, 이미지 2/2
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: 7 단계, 이미지 1/2 Amazon Fire TV Cube Motherboard Replacement: 7 단계, 이미지 2/2
    • Gently pry the motherboard up and off.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Piper Kaul
회원 가입일: 09/27/18
235 평판
안내서 2개 작성하였습니다
댓글 2개
where do you buy the mother board ?
Sam Handa - 답글
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 23
전체 시간: 1,661
