소개
This guide will walk you through the step-by-step procedures to remove and replace the speaker in your Amazon Fire TV Cube. These steps are simple, however some require considerable force. To complete this replacement you will need a small screwdriver and opening tool.
필요한 것
Using a metal spudger, push down between the edge seals on the base and pry off the base.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
