주요 콘텐츠로 건너뛰기
Amazon Fire TV Cube Speaker Replacement
필요한 것
  1. Amazon Fire TV Cube Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Amazon Fire TV Cube Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Amazon Fire TV Cube Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Speaker Replacement: 2 단계, 이미지 1/3 Amazon Fire TV Cube Speaker Replacement: 2 단계, 이미지 2/3 Amazon Fire TV Cube Speaker Replacement: 2 단계, 이미지 3/3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Speaker Replacement: 3 단계, 이미지 1/1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Speaker Replacement: 4 단계, 이미지 1/2 Amazon Fire TV Cube Speaker Replacement: 4 단계, 이미지 2/2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Justice Davis
회원 가입일: 09/27/18
228 평판
안내서 1개 작성함
댓글 한 개
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 3,306
