주요 콘텐츠로 건너뛰기
Amazon Fire TV Remote Control Button Panel Replacement
필요한 것
  1. Amazon Fire TV Remote Control Button Panel Replacement, Batteries: 1 단계, 이미지 1/2 Amazon Fire TV Remote Control Button Panel Replacement, Batteries: 1 단계, 이미지 2/2
    • Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
    • Lift the battery cover up to expose the batteries.
  2. Amazon Fire TV Remote Control Button Panel Replacement: 2 단계, 이미지 1/2 Amazon Fire TV Remote Control Button Panel Replacement: 2 단계, 이미지 2/2
    • Use your index finger to push the battery back and lift up to remove the battery.
    • Repeat the procedure for the second battery.
    Do regular AAA batteries work? I changed the batteries and I am still not getting a signal.
    Caitlin Hunter - 답글
  3. Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Motherboard: 3 단계, 이미지 1/2 Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Motherboard: 3 단계, 이미지 2/2
    • Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
    Vorsicht! Es existieren zwei weitere Schrauben. Bitte Kommentar bei Schritt 5 unbedingt beachten.
    PMB - 답글
    One screw may be under a sticker on the bottom. Found that out the hard way.
    Jayme Mueller - 답글
    new version does not have any screws. Its clicked together.
    derkurt - 답글
  4. Amazon Fire TV Remote Control Button Panel Replacement: 4 단계, 이미지 1/2 Amazon Fire TV Remote Control Button Panel Replacement: 4 단계, 이미지 2/2
    • Locate the bottom of the remote control.
    • Place your thumb on the bottom part of the remote. Apply pressure as shown in the picture to release the back panel from the front of the case.
  5. Amazon Fire TV Remote Control Button Panel Replacement: 5 단계, 이미지 1/2 Amazon Fire TV Remote Control Button Panel Replacement: 5 단계, 이미지 2/2
    • Insert a plastic opening tool in the gap and apply some force to disconnect the two pieces away from each other.
    • Since there are two pins keeping the back of the case together with the motherboard, some force is needed to separate them.
    Vorsicht! Dieser Schritt ist falsch, da sich unter einer Abdeckung zwei weitere Schrauben befinden. Wenn man die Fernbedienung jetzt mit Gewalt öffnet, brechen die beiden im Kunststoffteil eingegossenen Metallinnengewinde heraus!
    Vorab muss eine weitere kleine Kunststoffabdeckung abgehebelt werden. Wenn man gedanklich den Batteriedeckel längs bis zur Front der Fernbedienung verlängert, so ist gerade der verbleibende Rest des Bodenteils gemeint, der eben nicht Teil der Batterieabdeckung ist, jedoch ebenfalls im Querschnitt bogenförmig ist. Dieser ist an beiden Seiten der Fernbedienung eingerastet und zudem mit doppelseitigem Klebestreifen angebracht, daher einseitig ausklinken und dann vorsichtig dem Bogen entlang lösen. Darunter befinden sich zwei weitere Schrauben!
    PMB - 답글
  6. Amazon Fire TV Remote Control Button Panel Replacement: 6 단계, 이미지 1/1
    • Unscrew the seven 2.4 mm Phillips J#00 screws that connect the motherboard to the case.
  7. Amazon Fire TV Remote Control Button Panel Replacement: 7 단계, 이미지 1/1
    • Place the plastic opening tool or your fingernail in the gap at the top end and lift the motherboard.
    Schritt 5 ist leider flasch, da man mit dieser Methode die eingelassenen Muttern herausreißt. Man muss die geklebte Kappe entfernen, dann kommen zwei weitere Schrauben zum Vorschein die sich lösen lassen.
    Dann muss man die Kappe zwar beim Zusammenbauen neu kleben, aber hat dafür nicht die Muttern rausgerissen.
    Torsten Reuter - 답글
    Anleitung überarbeiten! Sie ist falsch.
    Wie der Vorredner bereits schreibt muss erst die geklebte Blende bei den zwei verdeckten Schrauben abgehebelt werden! Das Gehäuse der Fernbedienung wird ansonsten beschädigt. Grober Schnitzer.
    Hotzge Hotzge - 답글
  8. Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Button Panel: 8 단계, 이미지 1/2 Amazon Fire TV Remote Control Button Panel Replacement, Remote Control Button Panel: 8 단계, 이미지 2/2
    • Locate the black plastic tab at the top end of the button panel, grab it with your fingers and pull back to separate the button panel from the remote control's case.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Alejandro Franco Ceron
회원 가입일: 09/01/15
739 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-3, Wollert Fall 2015 USF Tampa, Team 16-3, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G3
4 회원들
안내서 16개 작성하였습니다
댓글 3개
The guide is wrong on step 7, there are 2 more hidden screws behind the plastic curved cover on top. If you get those out, you don't have to apply force to open. With step 7 you brake the metal nuts out of their place.
Raul - 답글
I’m also not quite convinced about step 5 - the metal nuts are also broken out there, and I can’t seem to get them back in, leaving the case 1mm open round the top.
Romax - 답글
I too popped it open with force and found the 2 nuts pulled out of their sockets. I was able to remove the screws from the case, then re-insert the screws into the nuts and punch them (hard) back into the little socket holes. They stuck fast, and didn’t spin when I reassembled the remote.
Ronald Goers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 97
30일 전: 323
전체 시간: 23,636
