필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Forget about using kindling—Amazon is pouring gas on the media box fire. Get ready to set your TV ablaze with these smokin' tech specs:
Quad-core, 1.7 GHz Qualcomm Krait 300 processor
Qualcomm Adreno 320 dedicated GPU
2 GB LPDDR2 RAM at 533 MHz
8 GB internal storage
MIMO Wi-Fi supporting 802.11a/b/g/n
Bluetooth 4.0
More than just a TV box, the Fire TV has power to spare for games, and for a little extra dough you can get this snazzy gamepad controller.
The otherwise featureless black box has a rainbow of ports on its rear:
5.5 mm DC Jack
Type A HDMI 1.4b output, w/HDCP
Optical Audio (TOSLINK)
10/100 Ethernet
USB 2.0 Type A
We've had enough of the etchings; it's time to get inside.
Go, go, plastic opening tool!
We dispatch the plastic clips to gain access to the Fire TV's internals. This hotshot may be tightly sealed, but it's no match for our icy blue opening tools.
On the flip-side we've got some runes:
Model CL1130
6.25 Volt DC Input
Federal Communications Commission Approval
Precision driving is not only a skill—it's a sport. We drive through a series of screws on the motherboard with precision far surpassing that of Imperial Stormtroopers.
With just a few turns, this board-in-a-box is on the loose.
Hey! Who left their bubblegum in our magic TV box? Gross.
Muppet news flash: Fire seems to put off a lot of heat. To keep this toasty box from catching fire, Amazon included a heatsink that fills most of the top case.
In addition to aforementioned hefty thermal gum wads. Ah, the sweet taste of cooling.
Keeping cool under the HDMI port, we find a little antenna, chilling all alone, not tied back into the system. With a tiny chip in the center, this looks like an RFID sticker, probably for inventory or tracking during manufacturing.
이 단계에 사용된 도구:iOpener$19.99-
Our first attempt at removing the heat sink involves an iOpener and an overwhelming lack of luck.
So begins the epic struggle...
Fortunately, we're experienced with both fire and ice as we use the old ice-cube-tray-twist to dislodge this heatsink.
The judicious combination of warmth and wiggling vanquishes this mighty foe.
The Fire TV is packing a pile of pyrotechnic chips:
Samsung K3PE0E00QM-CGC2 2 GB LPDDR2 RAM—the same we found in the Moto-X. The quad-core, 1.7 GHz Qualcomm Krait 300 processor is layered beneath the RAM.
Toshiba THGBM5G6A2JBAIR 8 GB eMMC NAND flash
Qualcomm PMM8920 power management IC
Atheros AR8152-B PCI-E fast ethernet controller
Pericom PI6C557-03ALE PCI-E clock
Texas Instruments DIT4192 digital audio transmitter
And on the back, a Qualcomm Atheros QCA6234XH integrated dual-band 2x2 802.11n + Bluetooth 4.0 chip, the same seen on the Kindle Fire 7" HDX.
With the Fire doused, we direct our efforts towards the remote.
Replaceable batteries? Check. We dread the day when even remotes no longer house removable batteries.
Remote, disassemble!
Apparently the voice search is not as advanced as we hoped. Alas, we will resort to using a screwdriver and opening tools to pry open the remote/microphone combo.
Another component, another RFID tag. Looks like Amazon is rooting for a different kind of dystopian future than we'd all imagined.
Round two of board-in-a-box primarily features a bit of Texan muscle:
Texas Instruments MSP430F5435A 16-bit ultra low power microcontroller
Texas Instruments CC2560 dual-mode Bluetooth Classic and Low-Energy (BLE)
Winbond W25Q40BW serial flash memory with dual and quad SPI (Serial Peripheral Interface)
MD v1.2 microphone, the same one seen in the Kindle Fire HD
Audience es305 voice processor
That's a wrap! Well, for this act anyway. Enjoy a remote layout by way of intermission.
But wait...there's more! Round three of this teardown brings us to the gaming controller.
The controller is tamper-proofed with a variant of the tri-wing screw family. They look cool and resemble shurikens, but we don't know anybody who keeps a shuriken driver on their tool belt.
Outwitting the strange screws, we pop this controller open. At least there's no adhesive keeping it shut.
And to complete the trifecta, there lies the controller's RFID tag.
We tweeze out little trigger button boards like splinters.
There's no time for a status report as we quickly free the status light and its
little green friendboard.
Next we pull the trigger...off the controller's motherboard.
We've touched the
Flying Spaghetti Monstermotherboard, and we're ready for some tasty treats: -
CSR CSR8670 audio and Bluetooth system-on-chip
NXP LPC812 Cortex-M0+ 32-bit microcontroller
Winbond 25Q16DW serial flash memory with dual and quad SPI
Texas Instruments HC595 8-bit shift registers
NXP HC4052 dual 4-channel analog multiplexer/demultiplexer
Boy howdy, it's your lucky day, reader! A second (gamier) layout, just for you.
Amazon Fire TV Repairability Score: 6 out of 10 (10 is easiest to repair)
Simple construction—upper case, lower case, heat sink, motherboard. Once it's apart, there's not much to keep track of.
The power supply is separate; should it ever need replacement, there'll be no disassembly required.
Standard Phillips screws populate the internals, making this box a worry-free affair once you're inside...
...provided you never need to remove the heat sink, which is secured with copious amounts of extremely sticky glue.
The outer case is a very tight fit. Plastic clips are used rather than glue, but they're so stubborn you'd be forgiven for thinking otherwise.
A single board hosts all the vitals—clean and simple, but when it comes to repair, it's all or nothing.
댓글 5개
Regarding RFID. I am pretty sure that this is related to the binding device to the Amazon account. When I bought fire tv stick and turned it on, it showed already my amazon account and asked me to confirm. This could be only possible, if they read device ID in warehouse during processing my order and bind it to my account. Easiest way to do this just to read RFID tag during packaging, so they do not need to scan any paper labels on box.
For accessories: they could be used to bind them all together on factory with some special tool by scanning RFIDs fully automatically. Or may be available for QA if all components present in a package during packaging on factory, or even just for future use.
wbr
Mike
I want to know where the reset pins are to initiate a restore. Mine is stuck on amazon fire TV logo one day I turned it on. It was after I loaded a kodi install file. Anyway when unloaded it and came back after an hour or so I get thisboot loop. Remote dont respond and I know it was paired and has new batteries. Also tried android but it ask for.a pin onscreen and that's not happening. I'm a technician and I know there has got to be some reset pins some.where. help if you can. Who's got the schematic??
im pretty sure u just plug in a keyboard and a menu pops up. don't do like me and pop it open, i fried something. super !#^&@@
Did you ever find a schematic?
