주요 콘텐츠로 건너뛰기
Amazon Kindle 8 Back Cover Replacement
필요한 것
  1. Amazon Kindle 8 Back Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Amazon Kindle 8 Back Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Amazon Kindle 8 Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
  3. Amazon Kindle 8 Back Cover Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Amazon Kindle 8 Back Cover Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Back Cover Replacement: 4 단계, 이미지 2개 중 1개 Amazon Kindle 8 Back Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Back Cover Replacement, Back Cover: 5 단계, 이미지 1개 중 1개
    • Separate the motherboard and the back cover.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
2다른 기여자 명과 함께
Luke
회원 가입일: 09/25/24
432 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 454
