주요 콘텐츠로 건너뛰기
Amazon Kindle 8 Power Button Replacement
필요한 것
  1. Amazon Kindle 8 Power Button Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Amazon Kindle 8 Power Button Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Power Button Replacement: 2 단계, 이미지 2개 중 1개 Amazon Kindle 8 Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
  3. Amazon Kindle 8 Power Button Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Amazon Kindle 8 Power Button Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Power Button Replacement: 4 단계, 이미지 2개 중 1개 Amazon Kindle 8 Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Power Button Replacement, Power Button: 5 단계, 이미지 2개 중 1개 Amazon Kindle 8 Power Button Replacement, Power Button: 5 단계, 이미지 2개 중 2개
    • On the back cover, from the outside of the kindle, use your finger to push the power button through its hole.
    • Remove the power button.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
2다른 기여자 명과 함께
Luke
회원 가입일: 09/25/24
432 평판
안내서 5개를 작성함
1가이드 댓글
partial fix, that does not show how to remove and replace the button in the subject. Please integrate step-by-step guide.
SimoneGallina - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 69
전체 시간: 526
