주요 콘텐츠로 건너뛰기
Amazon Kindle DX SIM Card Replacement
필요한 것
  1. Amazon Kindle DX SIM Card Replacement, Sim Card: 1 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to push against the top part of the e-reader to open the device.
  2. Amazon Kindle DX SIM Card Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the plastic top.
  3. Amazon Kindle DX SIM Card Replacement: 3 단계, 이미지 2개 중 1개 Amazon Kindle DX SIM Card Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the two small screws on each corner.
    • Remove the two 40mm screws with a Phillips #0 screwdriver.
  4. Amazon Kindle DX SIM Card Replacement: 4 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to take the off the metal plate.
  5. Amazon Kindle DX SIM Card Replacement: 5 단계, 이미지 1개 중 1개
    • Locate and remove the SIM card slot.
  6. Amazon Kindle DX SIM Card Replacement: 6 단계, 이미지 1개 중 1개
    • Use the spudger to push the metal lid backwards, as pictured.
  7. Amazon Kindle DX SIM Card Replacement: 7 단계, 이미지 1개 중 1개
    • Open the lid to replace the SIM card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Hassan Haseeb
회원 가입일: 09/28/16
189 평판
안내서 1개를 작성함
USF Tampa, Team 1-5, Cagle Fall 2016 USF Tampa, Team 1-5, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G5
3 회원들
안내서 10개를 작성함
3가이드 댓글
Need to do this with a kindle I have is does it need to be replaced with a 3G sim
Melanie Tague - 답글
I have 10 kindle Docs, first or second generation. I am too old to use the new kindles, fire, paperwhites. Can I make my old kindles work? I have them for different genres, 3200 books total. Please before I’m too old to care. Thank you for your time. I’m desperate.
Lilli Bean
Lillibean - 답글
DXs. Spellcheck messed up. Not me!
Lillibean - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 44
전체 시간: 4,129
