주요 콘텐츠로 건너뛰기
Amazon Kindle Oasis 8th Gen Back Panel Replacement
필요한 것
  1. Amazon Kindle Oasis 8th Gen Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
  2. Amazon Kindle Oasis 8th Gen Back Panel Replacement: 2 단계, 이미지 1/3 Amazon Kindle Oasis 8th Gen Back Panel Replacement: 2 단계, 이미지 2/3 Amazon Kindle Oasis 8th Gen Back Panel Replacement: 2 단계, 이미지 3/3
    • Work your way around the back panel to free all the clips.
    • There are 5 clips on the long and thickest side of the oasis, and none on the others.
  3. Amazon Kindle Oasis 8th Gen Back Panel Replacement: 3 단계, 이미지 1/2 Amazon Kindle Oasis 8th Gen Back Panel Replacement: 3 단계, 이미지 2/2
    • Carefully remove the back panel from the device.
    • Gently peel the back panel away from the adhesive, being mindful to keep the adhesive strip in good condition so that it can be used again.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Owens
회원 가입일: 09/27/17
152 평판
안내서 1개 작성함
USF Tampa, Team S16-G5, Eyestone Fall 2017 USF Tampa, Team S16-G5, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 49
전체 시간: 5,364
