소개
This guide is going to teach you how to remove the back panel of the Kindle. Behind the back panel, you will find the Kindle's components for functioning. Once you learn how to remove the back panel, you'll be able to do a lot more to your Kindle. This guide will teach you how to remove and replace the back panel of your Kindle.
필요한 것
Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
다른 한 분이 해당 안내서를 완성하였습니다.
