주요 콘텐츠로 건너뛰기
Amazon Luna Controller Joystick Cover Replacement
필요한 것
  1. Amazon Luna Controller Joystick Cover Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the controller over so that the back panel is facing up.
  2. Amazon Luna Controller Joystick Cover Replacement: 2 단계, 이미지 3개 중 1개 Amazon Luna Controller Joystick Cover Replacement: 2 단계, 이미지 3개 중 2개 Amazon Luna Controller Joystick Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
  3. Amazon Luna Controller Joystick Cover Replacement, Faceplate: 3 단계, 이미지 1개 중 1개
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
  4. Amazon Luna Controller Joystick Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
  5. Amazon Luna Controller Joystick Cover Replacement: 5 단계, 이미지 2개 중 1개 Amazon Luna Controller Joystick Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Once all clips are released, lift the front plate away from the controller.
  6. Amazon Luna Controller Joystick Cover Replacement, Buttons: 6 단계, 이미지 2개 중 1개 Amazon Luna Controller Joystick Cover Replacement, Buttons: 6 단계, 이미지 2개 중 2개
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
  7. Amazon Luna Controller Joystick Cover Replacement: 7 단계, 이미지 2개 중 1개 Amazon Luna Controller Joystick Cover Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
  8. Amazon Luna Controller Joystick Cover Replacement: 8 단계, 이미지 3개 중 1개 Amazon Luna Controller Joystick Cover Replacement: 8 단계, 이미지 3개 중 2개 Amazon Luna Controller Joystick Cover Replacement: 8 단계, 이미지 3개 중 3개
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
  9. Amazon Luna Controller Joystick Cover Replacement, Joystick Cover: 9 단계, 이미지 2개 중 1개 Amazon Luna Controller Joystick Cover Replacement, Joystick Cover: 9 단계, 이미지 2개 중 2개
    • Gently pull the joystick thumbstick straight up to remove it from the controller.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Cade Queen
회원 가입일: 09/04/24
537 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 215
