주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AmazonBasics B00Q3KFX8U Power Cable Replacement
필요한 것
  1. AmazonBasics B00Q3KFX8U Power Cable Replacement, Drive Gear: 1 단계, 이미지 1개 중 1개
    • Remove the shredder assembly from the paper scrap bin.
  2. AmazonBasics B00Q3KFX8U Power Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 10mm PH1 screws holding the small black panel in place.
  3. AmazonBasics B00Q3KFX8U Power Cable Replacement: 3 단계, 이미지 2개 중 1개 AmazonBasics B00Q3KFX8U Power Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
  4. AmazonBasics B00Q3KFX8U Power Cable Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
  5. AmazonBasics B00Q3KFX8U Power Cable Replacement: 5 단계, 이미지 2개 중 1개 AmazonBasics B00Q3KFX8U Power Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
  6. AmazonBasics B00Q3KFX8U Power Cable Replacement: 6 단계, 이미지 1개 중 1개
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
  7. AmazonBasics B00Q3KFX8U Power Cable Replacement: 7 단계, 이미지 2개 중 1개 AmazonBasics B00Q3KFX8U Power Cable Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
  8. AmazonBasics B00Q3KFX8U Power Cable Replacement, Motor: 8 단계, 이미지 1개 중 1개
    • Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
  9. AmazonBasics B00Q3KFX8U Power Cable Replacement: 9 단계, 이미지 1개 중 1개
    • Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
    • To reattach the motor, solder the wires back together, or to the motherboard depending on how you removed them.
  10. AmazonBasics B00Q3KFX8U Power Cable Replacement, Power Cable: 10 단계, 이미지 1개 중 1개
    • Remove the two 8mm PH1 screws holding the IR sensor wire in place. This will give you more room to work with later on.
  11. AmazonBasics B00Q3KFX8U Power Cable Replacement: 11 단계, 이미지 2개 중 1개 AmazonBasics B00Q3KFX8U Power Cable Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the two 10mm PH1 screws holding the motherboard in place.
    • Remove the motherboard by lifting straight upwards from the top cover.
  12. AmazonBasics B00Q3KFX8U Power Cable Replacement: 12 단계, 이미지 1개 중 1개
    • To disconnect the power wire, remove the black and white wires on the far edges of the motherboard.
    • To reassemble, solder the wires back to the motherboard in the same location as they previously were.
    • When reassembling, be sure to replace the wires in the correct locations. Reversing the wires will short circuit the motherboard and may damage the device or injure yourself.
결론
작성자
1다른 기여자 명과 함께
William Foley
회원 가입일: 03/25/16
548 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-3, Miles Spring 2016 UMass Dartmouth, Team 1-3, Miles Spring 2016 회원
UMASSD-MILES-S16S1G3
2 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 15
전체 시간: 797
