소개
The power switch is what turns the AmazonBasics on or off, as well as controlling the direction the shredder gears rotate. With age and extended use, the switch may sometimes break and require replacing.
필요한 것
Remove the two 8mm PH1 screws holding the IR sensor wire in place. This will give you more room to work with later on.
거의 끝나갑니다!
결론
