주요 콘텐츠로 건너뛰기
AmazonBasics BTV1 Motherboard Replacement
필요한 것
  1. AmazonBasics BTV1 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull out the two ribbon connectors to disconnect the motherboard from the case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chris Shannon
회원 가입일: 02/01/16
1,039 평판
안내서 5개를 작성함
USF Tampa, Team 14-2, Lacy Spring 2016 USF Tampa, Team 14-2, Lacy Spring 2016 회원
USFT-LACY-S16S14G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 638
